Content Filtering
HTH
Content Filtering
I have a problem with Content Filtering. I have URL's being blocked even though it does not look like these are categorized under any blocked category. For example, the URL http://inschool.gr/ is blocked even though it is in the Education category which is not blocked.
Additionally, it looks like the URL is still blocked even after adding it to the Allowed URL list
I have no Group Policies blocking content and the URL in question is not in the Blocked URL list.
Any idea what I could be missing?
You need to open a support case.
10 Replies 10
What version are you running?
HTH
MX 18.106
Do you have same issue with version  17.10.4?
HTH
No, the problem appeared after going from 17.10.2 to 18.106.
well, version still stable candidate release, so I suggest you to open a support case ou downgrade It.
HTH
Well, I'll try downgrading to see if this solves the problem first. Thanks for your help.
HTH
The downgrade worked. The sites in question work normally now. That means that it has to do with 18.106 but what is the problem? Should I wait for a new version before upgrading?
On the content filtering page, there is a link to lookup the category of a URL.  Try using that to verify which category the system thinks it is in.
HTH
Yes, I tried it. In the example above it lists the site under Education but the category is not blocked.
