MX84 and HA
Gordon
MX84 and HA
I am trying to understand how these firewalls work with HA.   Part of the issue is how my current firewalls work.
On my current firewalls I have the following
WAN Firewall-1 11.11.11.02  Firewall-2 11.11.11.03 Firewall VIP 11.11.11.01
LAN   Firewall-1 22.22.22.02  Firewall-2 22.22.22.03 Firewall VIP 22.22.22.01
So the VIP gets assigned to the active firewall so that the default gateway does not change.
How does this work with Meraki?  I don't see where I can enter VIPs for the LANs
Gordon
Thanks for the quick reply
I read this before but I missed some of it.   Just so I know how the underlying system works.
WAN - I can assign a VIP to it to be used as the default gateway which will follow the active firewall
LANs - Since the LANs do not get assigned a VIP, do they both get the same IP (active and passive) so that the default gateway on the LAN does not change.
That is correct Gordon.
