Does anyone have experience with the MX80?
We are having the issue that the throughput gets lowered by 50% compared to a direct connection with my macbook.
I saw that there are problems with this and that Meraki would fix it in an firmware upgrade, does anyone know about this?
Thank you.
Hi, did you try upgrading it to the latest Beta version trough Organization -> Firmware upgrades ?
Which version are you running currently ?
Regards,
Grega
No not beta yet,
If you are not in critical production enviroment yes, although from my experience beta is not a good thing to run in production, but for the sake of testing I would go for it yes ...
How many active users do you have behind your MX? Are you using all the Advanced Security Features? Content filtering, IDS/IPS?
5 users
Everything is disabled at the moment.
The MX80 is getting a bit long in the tooth now. When you connect your Mac Book directly what throughput do you get?
According to an old spec sheet I found the advanced security throughput should be 125Mb/s and it can support up to 100 users.
https://meraki.cisco.com/lib/pdf/meraki_datasheet_MX90.pdf
Are you sure you don't have any traffic shaping configured?
https://documentation.meraki.com/MX-Z/Firewall_and_Traffic_Shaping/Traffic_Shaping_Settings
Directly on the PPPOE network I get 98 Mb/s
On the Meraki I get 48Mb/s
All traffic Shaping not configured.
Try setting speed and duplex to static instead auto.
Could be worth the try, will check with internet company., thanks.
