MX75 SD-WAN DHCP relay setup with VLANS
carlfitzsimmons
Just browsing
I am setting up an MX75 with SD-WAN with 3 VLANS
  • 1 (192.168.1.0/24)
  • 10 (192.168.10.0/24)
  • 100 (192.168.100.0/24)
VLAN 100 needs to relay DHCP requests to 192.168.100.10. When I set VLAN 100 to relay DHCP to 192.168.100.10 this fails when you go to save.
This is the error:
There were errors in saving this configuration:
  • The DHCP relay IP address 192.168.100.10 cannot be in the subnet that is being relayed.
I have set many L2-L3 devices to relay requests to another DHCP Server in the same subnet.
How can I setup VLAN 100 to send DHCP requests to 192.168.100.10 so I can then set the switchports to access VLAN 100 so those devices can send a request then receive a DHCP address from 192.168.100.9?
1 Reply 1
Ryan_Miles
Just disable DHCP on VLAN 100 on the MX. Clients will broadcast their DHCP request on VLAN 100 and your server at .10 will receive it and reply.
