MX68CW licensing
nikmagashi
MX68CW licensing
I need some information regarding the licensing of MX68CW. What kind of a license can I use for it in order to be able to manage it through dashboard. Can I use an MX68 license for it?
BR
Brash
The MX68CW has its own licensing SKU's.
For example LIC-MX68CW-ENT-3YR
rwiesmann
As I know you need a dedicated license for the MX68CW...which means that you can choose for the MX68CW for either Enterprise, Advanced Security and Secure SD-WAN Plus.
For details see the following documentation on the options.
https://documentation.meraki.com/General_Administration/Licensing/Meraki_MX_Security_and_SD-WAN_Lice...
Hope that helps
Roger
Enterprise, Advanced Security or Secure SD-WAN Plus.
Those are three options to choose one.
KarstenI
And make sure to order the right MX Product Edition for your Org. You will find this info in your Dashboard under Organisation -> License Info
