The initial setup MUST be done over a wired connection, but as soon as an access to internet is provided via wired connection you can move over to the LTE and it will Merakily just work with LTE as primary uplink.
I´ do not know if you have to use wired connection with the Z3 to connect but I assume so for initial setup.
Welcome to the Meraki Community! To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
