MX68 SD-WAN & traffic shaping, WAN 1 and WAN 2
tantony
From our ISP, we're getting 100 down and 20 up.  When I do a speed test, I get 125 down and 20 up.  On the Meraki, I have WAN 1 and WAN 2 set to maximum Mbps (450).
Is it recommended to just leave it at that, or does it makes a difference if  set them to 100/20?
jdsilva
If you're using Load Balancing then it's important to set those values. If you just using them active/standby then it doesn't really matter.
jdsilva
tantony
ok thanks, I'm not using load balancing, so I'll leave the settings to default.
Nick
It can be helpful to set the values even without load balancing, incase you do some form of bandwidth management or QoS quality of service at some point. i.e splitting 20% of bandwidth for certain tasks
