MX67W Supported Antennas
pj4981
I see the MX67W includes two antennas with 2 x 2 MU-MIMO with two spatial streams.  Are there other antennas supported so I can locate them outside a metal equipment rack.
Ryan_Miles
Meraki Employee All-Star
The only antennas tested & supported are what is included. The connectors are RP-SMA however if you want to source non Meraki antennas keeping in mind my first sentence.
2 Replies 2
Ryan_Miles
BlakeRichardson
I agree it would be handy to have a model of the cellular MX with the option to use external antenna. I have a use case for installing an MX in a van to provide wifi to devices such as laptops however vans being mostly metal act like a faraday cage and I am concerned about what the signal quality will be.
