I have a new MX67C-WW and when I insert the LTE SIM in the slot, it does not connect to the internet.
I have tested the LTE SIM on another device, (LTE router, smartphone) and it works.
The MX67C-WW just doesn't seem to connect to the LTE network.
Solved! Go to Solution.
From this document:
https://documentation.meraki.com/MX/Cellular/3G%2F%2F4G_Cellular_Failover_with_USB_Modems
Please note that upon first-time bootup and connection to the Meraki Cloud, an ethernet WAN connection must be used to download the initial configuration and get the device online the first time.
Hi @Vhuphilo , you need to register the device to the internet via its WAN interface before failing over to LTE.
From this document:
Thanks, much appreciated.
Accepted.
