MX67 LSP is not accessible
Cyrus777
I’m having difficulty accessing the local status page on the MX67 across my organization. All other MX models are accessible without issues.
Current version: MX 19.1.11
I have several MX models deployed across my organization, and only the MX67 is behaving oddly.
I’ve been using the management VLAN interface IP address to access the web interface of the MX units, and all offices are bound to the same template with identical VLAN and firewall configurations.
Do you have any ideas on what might be wrong with the MX67 LSP?
Cyrus777
I found my answer.
If someone else come across the same issue look into this document. MX67 LSP is not loading normally over auto VPN. we must add port ":8092" at the end of URL from now on.
https://documentation.meraki.com/Platform_Management/Troubleshooting_and_Support/Troubleshooting/Usi...
9 Replies 9
Is the local status page enabled on device configuration?
Cyrus777
Yes it is.
As I mentioned all networks are bound to template and they have identical configuration.
I think it wouldn't hurt to do a double-check directly on the network and not on the template. 😉
rhbirkelund
If I remember correctly, network settings are not part of the templates, so these need to be configured on a per-network basis.
Have you tried configuring the LSP login on the MX67 network, and then trying to log in again?
JamesT91
These settings are only available on the template - the General page under network-wide is not available under the individual networks if bound to a template.
Cyrus777
the setting is part of template.
it works for all MXs but MX67
rhbirkelund
What if you reconfigured the LSP credentials? Does that work?
Cyrus777
I found my answer.
AlexP
Solutions to this are being worked on. MXs presented themselves as somewhat of a unique case compared to switching and wireless with the move to the TLS/HTTPS status page as of MX 19.1.11 onward. The initial implementation didn't recognize how often folks would be connecting to local status pages from across their VPN fabrics, so the way domains get resolved to avoid browser/cert warnings doesn't currently account for this.
