MX67 Clients
MarcM1
MX67 Clients
I have just setup an MX67 as a spoke connected to a VPN hub, it's working but in the Network-Clients section, Client list is showing external Public IP addresses. I have 2 other spokes setup back to the VPN hub and they just display the internal clients. Is this a configuration issue or do I need to contact my ISP?
Thanks in advance.
How is your DHCP scope configured?
Theoretically, no additional configuration is required.
Have you got the internal circuit connected via any internal switch ports, either in an MX or an MS?
This is a common trick for connecting two MX to one Internet port.
MarcM1
Thanks for the replies, I misunderstood the traffic flow, it's performing as it should.
