MX65 Connected Devices Upstream
Adoos
I have a MX65 with two Meraki ms120p connected.
When I go to the topology page it doesn't tell me which port the switches connect into on the MX65. It tells me port x/xx on the switch but doesnt actually say the physical port number on the MX.
Maybe i'm looking in the wrong menu? Make a wish?
Alas only the switches report the specific port that a device is connected to.
Adoos
Bugger, thats two big wishes.
Descriptions for MX ports and full CDP information.
benny
+1 on those two wishes. I've put these in before to Meraki
Adoos
Hey @benny
If you really need to find what port the switch is connecting with on MX you can get it from the raw LLDP data information on the switch ports.
1) Select your switch
2) Look for and select the Meraki worm symbol indicating the MX is connecting to it.
3) Clock "raw"
4) Look at the port ID.
