Anyone know if there is a way to change the settings on an MX64W to turn off Band-steering, or is this only possible if using a separate AP?
Solved! Go to solution.
You can only do it on the MR appliances.
I thought as much, but thought was worth checking in case I was missing something.
Thanks!
