The MX67C/MX68CW contains a 3G/4G modem which can be used for cellular failover (3rd WAN interface-ish).
Otherwise, no. All MX'es support only 2 WAN interfaces.
MX250 and up, have two dedicated ports. MX100 and below, has one dedicated port, and one shared, which can be converted.
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
