MX64 behind a netgear router
Tehsin
Hi I am new to networking.
I have received a promotional MX64 device.
Which I have setup behind my netgear router.
As a part of my learning process I am trying to connect to the network using the vpn client from a different network but I am failing to do that.
Can someone help me sorting this.
DarrenOC
Hi @Tehsin , firstly, is the MX registered out to the cloud and operational?
Are you using DDNS on the MX, are you connecting in via host name or IP?
https://documentation.meraki.com/MX/Other_Topics/Dynamic_DNS_(DDNS)
Are you seeing the vpn traffic hit your internet interface on the MX?  You should be able to see this via a packet capture.
if you’re not seeing that traffic your net gear may need to be configured with port forwarding for the vpn traffic. Ports 500 and 4500
Darren O'Connor | uccert.co.uk
1 REPLY 1
DarrenOC
