MX64 Rule matches
NGleich
MX64 Rule matches
Hi everyone,
I was having problems with an MX firewall rule block.
I have not found a way to see which firewall rule applied to the traffic.
(For layer 3 rules there is at least a hit counter ; for layer 7 rules not)
In network wide event log i can only see content filter blocks.
(My problem was because china was blocked as a layer 7 country rule, however it was just trial and error to find out about this).
So my question would be if there is a way to see which rules applied to traffic.
May it be like that because the MX is placed in bridging mode (layer 2 ?)
Hope someone can help.
BTW, it is not urgent since the given deployment is at my home for testing purposes.
Kind Regards
Niklas
2 REPLIES 2
GIdenJoe
If you run a syslog server behind the MX you can send syslog messages to it for every flow that is allowed or denied by the rules if you put logging on for a certain rule.
However I have never tested L7 rules on a syslog server so I'm not sure if it leaves an entry for those.
Might be worth testing.
Thanks, GldenJoe!
That's a good idea and I will test this.
Best Regards
Niklas
