MX64 HA Load Balancing
ehsan230564
Dear Sir,
If Two Meraki mx64 are in HA warm spare. And both the device WAN1 are connected to different ISP internet.
Is it possible to configure internet load balancing as well internet fail over between primary and spare WAN1.
Thanks and regards.
6 Replies 6
BrechtSchamp
No. Load balancing between MX's isn't supported. It's a warm spare failover system. More information here:
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
A better setup would be to have each MX connect to each ISP's router too.
@BrechtSchamp has a point
Enthusiast
But, is possible to connect the MX-64 to two different ISP and manage the load balancing between those 2 connections in just one MX-64 ????
thanks for the answer.
Yes. Check this document:
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
And this one to convert one of the LAN ports to a WAN port:
https://documentation.meraki.com/MX/Installation_Guides/MX64_Installation_Guide#Setting_up_secondary...)
thanks a lot for your answer. Just one more thing , where can i contact to a seller on my space area ?? wich partners do you have for suggest in Santa Cruz or Sucre - Bolivia.
Best Regards.
