MX450 add services & ports to restrict traffic
Jayt
Hi
Setting up a new MX450 to replace a Fortigate.  I need to allow 1 VLAN to talk to another VLAN only communicating on a specific set of ports & services.  Fortinet allows to make service objects with the ports then assign to a service group. Then on the policies I can assign the traffic to only use that service group.  I'm not seeing this on the MX. I called into support & the answer wasn't too good from them. Basically was told can't do that.
I'm told I have to use individual firewall rules for each port & each service from X VLAN to X VLAN.  This seems way too convoluted & will make the FW rules a mess.  I need to add 11 services with the specific ports.
Is there a work around or an easier way to do this?
12 Replies 12
Yes, you can create objects and then create a group of objects.
alemabrahao_0-1761743827365.pngalemabrahao_1-1761743872518.pngalemabrahao_2-1761743982012.png
Jayt
These are for server ports & services.  Example DNS, NTP, SQL, etc & then their associated ports. And have some custom software ports that need to be opened to the VLAN.
This is the only way; you can specify the ports and separate them with a comma, as I did.
RaphaelL
This was teased a long time ago , but never released. This might be coming with the "new" "Security" tab from the dashboard.
Yes, it's the same tab where Policy Objects are created.
MarcP
Just send a pic where you typed in the Ports @Jayt asked for, thats it, included where. Then you got the solution for him 🙂
In the Layer 3 rules, this was already implied to me 😉
Jayt
So the layer 3 rules are where I need to create these for each port?
Examples
Allow server to server TCP server1 6001 Server2 6001
Allow server to server UDP  server1 6001 Server2 6001
No, As you can see in the images I sent, you can separate the ports by commas and create objects for the IP or name of your servers. But, for UDP and TCP you need to create separate rules.
Jayt
Ok so I can do....
Allow server to server TCP server1 6001, 80, 443 Server2 6001, 80, 443
Allow server to server UDP  server1 6001, 80, 443 Server2 6001, 80, 443
Yes.
Jayt
Ok, thank you, I'll need to test next week to see if that all works.  I added all 11 of these & the NAT side.
