MX250 - convert copper LAN port to WAN port?
henleyjj
Hi All,
I have a question which might be pretty basic but I'm unsure of....
We have purchased a MX250 without any SFP+ modules for WAN connectivity for a customer. Therefore I was wondering if it's possible to convert one of the copper ports to a WAN port?
I know this is possible on MX64 but again I'm unsure of MX250.
jdsilva
@dalmiroy2k wrote:
Also, keep in mind that if you buy a 10 GbE SFP+ Fiber Transceiver, you also have to use a 10Gb SFP+ transceiver in the other endpoint you are connecting to. You can't downconvert the 10Gb SFP+ to 1 Gb speed in your MX 250.
Except, exceptions:
https://www.finisar.com/optical-transceivers/ftlx8574d3bcv
https://www.juniper.net/documentation/en_US/junos/topics/concept/dual-rate-sfp-plus-modules-acx-seri...
https://www.fs.com/products/29901.html
But note, none of those are Meraki certified 🙂
3 REPLIES 3
BrandonS
Negatory. You will need to get a SFP. You should be able to use any brand and may want to if time sensitive, but I would suggest getting them a Meraki one so it is all covered by support.
dalmiroy2k
jdsilva
Except, exceptions:
