You might consider taking a look at the free online training courses on the Meraki Learning Hub:
Implementing Firewall Rules on a Security Appliance
This module will enable you to:
- Configure and deploy layer 3 firewall rules
- Configure and deploy layer 7 firewall rules
- Describe how the Meraki security and SD-WAN appliance processes layer 3 and layer 7 rules
- Configure and implement firewall policy objects
- Enable ICMP, SNMP, and local status page access from the WAN
You would want and need to be methodical on how you add the list (order of precedence) and not just all thrown on a webpage without regard to the sequencing or order - the rules would need to be applied from a holistic top down sequence which does take planning and a little bit of organization according to your network needs.
Layer 3 and 7 Firewall Processing Order
Network objects can be utilized and often best if you and your fellow admins come up with a semi-standardized naming convention if you have a complex environment.
Network Objects Configuration Guide
And lastly, if you apply any custom group policies with custom L3/L7 firewall rules the default rules wouldn't apply as you are telling the client to use whatever custom group policies vs the default so that is another factor to take into the equation.
The hit counter only increments for traffic that matches the rule exactly.
If you’re not seeing hits, double-check the source/destination, protocol, and port definitions.
DNS traffic (port 53) may be bypassing the MX if clients use external DNS.
