It mentions that the MX250 has 2x 10GbE SFP+ WAN ports. Can a 1Gbit SFP work on these ports or only 10GbE SFP's? This is important to know as only our DC services have 10Gbit interface handoffs.
Yes, this question was just recently handled, but the question was if the 1 GbE coppar SFP was compatible. Have a look on this thread below. As I understand it has been tested and it does work with 1 Gb SFP in the 10 Gb SFP ports.
Thanks Claes_Karlsson, i did see the SFP datasheet but i didn't find it mention whats compatible for the WAN SFP ports in comparison to the LAN SFP ports and the MX datasheet just says 10GbitSFP+ for the WAN ports without specifying the 1Gbit so i was a little thrown off.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_67159f4dfbefad","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_67159f4dfbefad_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_67159f4dfbefad_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_67159f4dfbefad_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_67159f45508f52","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
