MX250 - Maximum Z1/Z3 connections
Lagcat
Hello
due to the fun of the current virus spreading out company is looking to purchase a large amount of Z3 devices to hang off the back of our MX250 with 2x1GB lines
is there any limit I should configure apart from the 1GB vpn throughput?
will I reach any limit of the site-site connections?
we are looking to purchase anywhere between 100-800 devices - mainly going to be a small amount of application and voice traffic
Cheers
Jake
Meraki sheet https://meraki.cisco.com/lib/pdf/meraki_whitepaper_mx_sizing_guide.pdf
Keep in mind the tunnel count and recommended tunnels. A good guide here:  https://www.willette.works/meraki-mx-sizing/
BrechtSchamp
Indeed, what @ww said. In the case of the MX250 the maximum number of tunnels is 3000, so you should be fine with 800 Z1/3's.
Edit: @ww correctly pointed out to me that the maximum recommended number of tunnels for the MX250 is 1000. If your MX is using dual uplinks that means you'll need 2 tunnels per Z1/3. So 800 would result in 1600 tunnels. I still think you will be fine with the 800 as you'll still be under 3000 tunnels which is the max number of tunnels.
Lagcat
thanks all for the replies
looks like we are going to move forwards
thank you
