I have AutoVPN setup on 2 sites with MX100's
All is working as expected apart from one subnet on HUB site.
I had to connect the Lan of the MX on a existing network so usually on a Cisco ASA you set up Lan interface as /32 ip and route out to the gateway of the subnet connected but on MX when you set up the LAN as /32 it refuses and requires a /30 minimum subnet.
At this time i can access all Vlan's apart from the lan interface lan devices, I.e the server A, or any other device on 10.255.255.0/24.
Is there to make this work?
