MX100 External Address Range
Q313
Hi team,
    I need to setup a site-to-site VPN tunnel and I cannot find/figure out how to use one of my external ip addresses.  I have 6 addresses with which to use, but don't see how to accomplish this with the Meraki MX100.
In contrast, I can succesffully use 1:1 Nat to utilize an external IP for a device on my LAN.
Ive checked a few posts and they are related to the above type of configuration.
An older post stated this is not possible (no agreed to or denied the claim however).
Any input on external ip ranges and site to site VPN?
Much appreciated 🙂
Any advice?
@Q313 from the document linked to by @DarrenOC :
Public IP - The public IP address from which the remote MX can be contacted. This can be found on the remote MX in Dashboard under Security & SD-WAN > Monitor > Appliance status > Uplink > Configuration > General > Public IP:
i.e. you can only build a tunnel to the device interface IP, not one of the other public IP addresses in the public range you have on the WAN port.  If you have two ISPs you can build a tunnel to either WAN port IP address.
6 Replies 6
DarrenOC
Hi @Q313 , this should help
https://documentation.meraki.com/MX/Site-to-site_VPN/Configuring_Site-to-site_VPN_between_MX_Applian...
BrechtSchamp
I'm not sure I understand the question. But in the case of two uplinks the MX should build tunnels over both uplinks automatically (unless NAT traversal doesn't work and you're using manual NAT forwarding).
If you're talking about a situation where there's a provider router in front of your MX and it's a NATed setup, it's up to that device to NAT the correct address.
This whitepaper goes quite deep into how the AutoVPN works:
https://meraki.cisco.com/wp-content/uploads/2020/05/meraki_whitepaper_autovpn.pdf
This article also mentions the fact that tunnels are built over both uplinks:
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-Site_VPN_Failover_Behavior
Q313
Thank you very much.
Sounds like despite the range of IP addresses I own, I can only use one IP via the Meraki uplink (or use a second uplink for a second address).
@Q313 if you have internal services that you want to publish externally you can use 1:1 NAT to map the internal servers to a unique external address.  You just cannot do this for VPN connections or subnets.
WillN
Might need a bit of clarity on this question.
When you say Site-to-site VPN, do you mean Meraki MX VPN services, or a device that sits behind the Meraki MX in a LAN port that is the source of the VPN connecting to another site OVER the Meraki MX?
