MX warm spare without LAN virtual IP ?
Mr-cook
I'm confused about configuring my meraki MX cluster :
In this documenation :
 https://documentation.meraki.com/MX-Z/Other_Topics/Warm_Spare
I found :
"LAN IP addresses are configured based on the Appliance IPs in any configured VLANs. No virtual IPs are required on the LAN."
How can I configure HA without LAN virtual IP ? What will be the gateway for my switch ?
Can anyone help please ?
It isn't written very well.  The MX's use VRRP, which in essence is a virtual IP.  The IP address is always serviced by the primary MX.  The spare takes over the VRRP IP address if the primary fails.
5 Replies 5
only 1 mx is active for all your vlans. you can't config the different vlans on the 2nd mx when they are in warm spare.
Mr-cook
Thank you PhilipDAth, is it the same for WAN interfaces ?
The WAN interfaces each need their own IP address, and if there is a common subnet, you can also enable a Virtual IP.  Using a virtual IP on the WAN interfaces is an optional configuration.
https://documentation.meraki.com/MX-Z/Other_Topics/Warm_Spare#Virtual_IP
Mr-cook
that's very clear, thanks a lot
