MX integration with Checkpoint cloudguard
Has anyone done or heard of MX integration with Checkpoint cloudguard? I'm planning a solution Basically the MX will be part of the SD-WAN but the security control will be done by Checkpoint cloudguard (SASE Solution).
Is it possible to do this integration?
Thanks.
I'm guessing it will be something similar to using Zscaler, which uses the tag based VPN failover system.
https://documentation.meraki.com/MX/Site-to-site_VPN/Tag-Based_IPsec_VPN_Failover
@PhilipDAth, I think it is a similar case. I will read and take all the notes.
Thanks @PhilipDAth
