MX device and trying to make multiple devices appear externally as a single public IP
GaryShainberg
Dear Meraki Friends,
I am trying to find a way to allow multiple IP’s to route from a single public IP address.
The situation is that we have a number of clients servers who have whitelisted a public single IP so we can access there servers so I know I can make 1 LAN IP appear externally as a public IP using 1:1 NAT but I have multiple users (devices) that need to do this potentially as the same time, anyone got any idea’s on how I can do this or any other suggestions.
Gary
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
5 Replies 5
Is this for outbound Nat?
Yes, thanks
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
MilesMeraki
If all the client devices are behind the MX/Device gateway performing NAT, just put all the clients into a specific VLAN and then create a group policy on that VLAN to be routed out of the WAN 2 uplink (Which has the specific whitelisted public IP).
 WANKiller, thanks for this, I think what complicated matters is that the ISP issues a dynamic IP for the WAN interface (PPPOE) but have issues a subnet which is routed, via this dynamic IP. one of the public IP's that have been allocated is the whitelisted IP to the remote servers.
I can use 1:1 NAT routing (say 192.168.200.200 to 62.172.116.200) so that all outbound traffic appears to come from this public IP but what I am trying to achieve is something like 192.168.200.0/24 to 62.172.116.200.
Any thoughts / help would be very much apreciared
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
I can't think of anyway to solve this one.  You can do inbound 1:many, but not outbound many:1 NAT.
