MX Wake on LAN failure
Richard
LAN with 5 or 6 VLANs dont see WOL packets when sent from a server
When a PC is asleep and the ARP table has been cleared the WOL does not get through to PCs on different VLANs
Anyone got a work around for this?
Does not happen on SonicWall only MXs
6 Replies 6
Its a layer2 protocol, so this also shouldnt work on sonicwall by default.
I read sonicwall has a solution for this but afaik meraki does not.
https://www.sonicwall.com/support/knowledge-base/how-do-i-allow-wake-on-lan-packets-to-pass-through-...
Richard
Thanks!
Did you know that Meraki has native wake on lan support?  You click on the client in the Meraki Dashboard, and can wake them up from there.
Richard
Thats ok if you want to do 1 or 2 but a hundred - and we want them to wake on a script every day at a set time
Here is the API call you can make from a script to do this.
https://developer.cisco.com/meraki/api-v1/create-device-live-tools-wake-on-lan/
Sample code in Python:
serial = 'Q2QN-9J8L-SLPD'
vlan_id = 12
mac = '00:11:22:33:44:55'
response = dashboard.devices.createDeviceLiveToolsWakeOnLan(
    serial, vlan_id, mac,
    callback={'url': 'https://webhook.site/28efa24e-f830-4d9f-a12b-fbb9e5035031', 'sharedSecret': 'secret', 'httpServer': {'id': 'aHR0cHM6Ly93d3cuZXhhbXBsZS5jb20vd2ViaG9va3M='}, 'payloadTemplate': {'id': 'wpt_2100'}}
print(response)
Note that the callback URL is optional - this just notifies you once it has been done.
I haven't tried this with the Meraki API, but with other systems you can specify a MAC address of ff:ff:ff:ff:ff:ff to send the WOL packet to every client in the VLAN at once, with a single call.
great thanks
Will get this tested if the guys think its suitable
We have used APIU for cameras and WiFi analytics
