MX WAN interface static IP configuration
Jyrki_Halonen
I have MX95 connected to MS-switch: WAN1 interface for ISP IC-network and LAN9 port for multiple internal VLANs.
ISP is connected with 2x1G LACP channel to switch and LACP is configured to 802.1Q trunk with IC-network tagged to VLAN 10.
Picture of connection:
MX firewall WAN should be configured with static IP address provided by ISP.
My question is: should I configure VLAN 10 IP to MX under:
- Security & SD-WAN / Configure / Addressing & VLANs / Routing          or
- Security & SD-WAN / Monitor / Appliance status / Uplink / WAN1
KarstenI
External Connections are always configured under Uplink/WAN. Addressing and VLANs is for all internal LANs and DMZs.
About your design: I would never configure it that way. In case of a switch failure, you build a physical bypass around your firewall and bridge the Internet into your internal LAN.
This really should be implemented with dedicated WAN-switches.
Jyrki_Halonen
About the design: I do have HA FW in place connected to switch-stack but I didn,t draw it to the picture since it is irrelevant for the problem.
KarstenI
It is not the HA; it's about having WAN and LAN on the same switch.
Jyrki_Halonen
Sure in ideal world everybody would HA everything, but as always it is the matter of cost and needs in small setups
