Hi all,
I am migrating an MX from one organization to another (same client). Once migrated, I would like to configure the WAN with the same static public IP. My question is: since there is no DHCP on the provider's side, is it possible that the signal won't connect?
My fear is that i will lose my MX .
Is it then better to configure via dashboard the interface statically before connecting it to the network, or is it safer to go to the client's site and set the IP via the Local Page?Whats the best practice?
Thank you.
