MX WAN Compatibility with other vendors SFP
TommyH
Just browsing
I have a Meraki MX250 to be installed. However, I forgot to purchase the Meraki SFP.
Is Cisco SFP compatible with Meraki MX250 WAN port?
Thanks,
Niklas2
Hey
yeah it should work, we used FlexOptics SFP and worked fine.
Here's a List wich SFP's are supported for wich model, if you have SFP's from Cisco with the same specs, go for it 🙂
https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf
8 Replies 8
Niklas2
Hey @TommyH ,
it is compatible but not certified yet.
Greets
TommyH
Just browsing
Which means the WAN interface is workable using Cisco SFP right?
Thanks,
Niklas2
Hey
TommyH
Just browsing
Will other vendors SFP (Cisco) cause any potential issue to the traffic or device?
For example, packet loss?
Thanks,
Niklas2
we don't have any issues with that sfps
TommyH
Just browsing
Okay, thanks a lot
Nick
As mentioned above, they should all work. However some are certified by vendors.
Just because they are not certified doesn't mean they won't work
jdsilva
We've run into problems when using LX/LH or SX optics on the WAN port of an MX right out of the box. It's always required a firmware upgrade before the WAN port will work with those optics. Same goes for using some 1G optics on the SFP+ ports.
