I have a Meraki MX250 to be installed. However, I forgot to purchase the Meraki SFP.
Is Cisco SFP compatible with Meraki MX250 WAN port?
Thanks,
Solved! Go to solution.
Hey
yeah it should work, we used FlexOptics SFP and worked fine.
Here's a List wich SFP's are supported for wich model, if you have SFP's from Cisco with the same specs, go for it 🙂
https://meraki.cisco.com/lib/pdf/meraki_datasheet_sfp.pdf
Hey @TommyH ,
it is compatible but not certified yet.
Greets
Which means the WAN interface is workable using Cisco SFP right?
Will other vendors SFP (Cisco) cause any potential issue to the traffic or device?
For example, packet loss?
we don't have any issues with that sfps
We've run into problems when using LX/LH or SX optics on the WAN port of an MX right out of the box. It's always required a firmware upgrade before the WAN port will work with those optics. Same goes for using some 1G optics on the SFP+ ports.
