Search instead for
MX VPN Concentrator behind small MTU network
I have a one-armed MX VPN Concentrator that is located in a site that is connected over a network with an MTU of 1440. Is there a way to build a Teleworker VPN solution (MR AccessPoint SSID Tunneling) from other sites to this VPN concentrator? Is there a way to reduce the MTU on the MX or to switch on PMTUD in a way that the MX and the AccessPoint both reduce the size of the IP packets?
Accepted Solutions
Re: MX VPN Concentrator behind small MTU network
If you call support they can modify the MTU of the MX interfaces for you. It is not exposed in the dashboard for you to do yourself.
3 REPLIES 3
Thanks for the reply!
No problem! Good luck with your config Smiley Happy
