- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
MX Template Static routing - Multiple sites
Hi All,
I have MX template has 100+ network. in each network the MX is connected to Cisco core switch. I will need to add static route to a different next hope in each site ?
So is site one has MX IP 10.10.10.1 and core of 10.10.10.2 , I need static for this site when try to reach for example 172.16.2.2 to go to next hope of 10.10.10.2
second site under the same template, Meraki MX IP 10.10.11.1 and core 10.10.11.2 and need to reach the same 172.16.2.2 need to go to 10.10.11.2
any was we can do that in the MX template? the static routing is not enabled locally on the appliance when it is under a template.
TIA.
Solved! Go to solution.
- Labels:
Firewall
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello AhmedJawad,
Static routing on the template can be configure using IP offsets, as described here:
Based on the example configuration you provided, each child network would use its own subnet, then add the provided offset for the next hop IP. This would work as long as the examples you provided are all that you are looking for with static routes.
If the next hop IP is inconsistent (for example, instead of 10.10.10.2 it was 10.10.10.245 in one network and instead of 10.10.11.2 it was 10.10.10.145 in another network), then this would not help since the offset differs for each network.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello AhmedJawad,
