MX Revert To Previous Configuration After Lose WAN connection
Iamyour_Joy33
Dear All,
I am writing this to get any experiences from all of you about MX revert to the previous configuration after losing WAN connection. This is the real case I have met in my organization, I have setup MX to reach to Meraki cloud and synced the configuration already and this MX connected to Meraki cloud more than a week. Later on, after I lose my WAN connection around 7 days, and WAN connection came back, MX configuration already revert to the previous one ( 192.168.0.1) and we need to configure it again to reach the Meraki cloud.
Does anyone have met this issue like me?
Please let me know if you have any concerns about this! Since TAC didn't believe when first time I open case.
Best Regards,
Joy
6 Replies 6
I saw this happen once with a client and if I'm not mistaken, the MX's RMA was necessary.
Iamyour_Joy33
Hi @alemabrahao , I got another MX that happen the same as this one but it did not revert to the previous configuration. Anyway, I have asked TAC to disable reboot every 4 hours when it is in safe configuration mode as I have read Meraki document.
Iamyour_Joy33
Hi, Since hardware is not issue. how could Meraki team accept to process RMA?
GIdenJoe
Usually that only should happen when you factory default the device.  If your device did that on it's own then you may have a faulty device or perhaps a firmware bug.
Iamyour_Joy33
Hi @GIdenJoe ,
I am not clearly sure about firmware bug. I'm running version 18.107.2 in my organization, in this scenario if my MX lost connectivity to Meraki cloud and the Internet port on MX is unplug, this issue won't happen but if WAN is still plugin with the Internet port in MX, it will revert to the previous configuration after losing connectivity to the cloud more than 7 days.
ABaker
I know this thread is a couple years old, I've experienced this too.  The issue appears to be a question of how the WAN ports are being configured.  The MX units ports can be configured through the Dashboard, but it will not stick or it will lie about a config.  My most recent experience is that our WAN1 port had to be configured with a Vlan ID tag for the traffic to reach the other side.  In the Dashboard, the tag was setup correctly.  When I consoled in, the tag was missing.  So, going forward, all new configuration changes to the MX WAN ports will have to be done through the console port, on site.
