We're migrating to the Cisco Community on March 29. The Meraki Community will enter read-only mode starting on March 27.
Hi Guys
It seems like a simple issue but I can't find documentation for it. I need to order power cables for the following devices.
MX250
MX95
MX85
I know some MX require the C15 connector and others require C13. Can you tell me which ones from the list require C15?
Solved! Go to solution.
C15 and C13 are compatible. Does this overview help further?
Awesome, I didn't consider the C15 to be compatible with the C13 but it obviously is as the C15 just has a notch cut out. Good spot and thanks.
According to the datasheet, MX's take the power cable MA-PWR-CORD-US which is a C13 cable.
If I remember correctly it's only some Meraki switches that take C15 cables.
I concur - I have only seen some of the switches using a C15.
After speaking with other internal engineers, we have some MX250 and MX450 with C15.
