MX Ports and API calls
Ken_B
I am in the process of deploying some MX68s that are not bound to a template.  I want to change the VLANs that are assigned to the MX ports.  When I send the PUT command from Postman I get a response of 200 OK but the change is not taking place.  I can run a get command and get the Port configuration but I just cannot change it.  Any suggestions
I don't know the answer.  Have you tried adding the port number to the request?
Ken_B
Yes I have and it did not make a difference.  The port number is in the header, as per the documentation.
Are you setting the Content-Type header?
Ken_B
I have it set to application/json
