MX Management Port
networkninja_
MX Management Port
Is it possible to setup the MX250 management port with a static IP address and access it for out of band? Wondering if this can be setup so we can remotely access the status page of the MX incase we lose connection to the Meraki cloud.
You can't configure it in anyway.
You would have to use a management with two interfaces. One plugged into the MX management port that got its config via DHCP, and the other connecting to the out of band network.
networkninja_
I'll give that a try, thanks!
GIdenJoe
It would be extremely handy to be able to configure it but it is not so 😉
networkninja_
Thank you!
