Thank you all for your replies. The interfaces/networks on the MX are more complicated than in the diagram, I just simplified it to try to remove any confusion. We have 5 different vlans/subnets, each with their own source-based route as the MX is also used to tunnel some wireless traffic, and the default gateway for each of these subnets is actually the router, which has those 5 interfaces/subnets on them.
I think the issue is routing, but on the return of the traffic. If I disable all firewall rules traffic originating from 10.1.0.0/24 can get to 10.112.5.0/24, however traffic originating from 10.112.5.0/24 passes through the MX to 10.1.0.0/24 (As can be seen in packet captures) and I can see the responses, but I suspect it's then following default routes, rather than source based routing for the return traffic. I'll confirm this by running packet captures on the different interfaces on the MX and check for the reply traffic going down a wrong route...
The firewall rules are working correctly as the ACL hit count is increasing as I send test data, so not as I originally thought being an issues with L3 firewall rules.
Once again, thanks for your responses, hopefully I can figure this out.
