MX LAN Link aggregation
ammahend
Can I aggregate LAN port 3 and 4 into a port channel on MX67 or any other MX for that matter ?
If not whats the best way to do LAN port redundancy on MX ?
1 Reply 1
Brash
No, port-channels are not configurable on MX devices.
The MX does however pass through STP packets so you can connect 2 cables to the same network.
One will be brought down (due to STP loop prevention) but can be used as a backup if the primary connection fails.
