Licensing for MS425-16 Core switches in physical stack.
JamesMutie
Hello community,
I found this in Meraki documentation.
Do I need duplicate licenses to cover my security appliance in a warm spare configuration?
No, if two security appliances are in a warm spare/HA configuration, licensing is only required for one of the two devices. The only additional cost of a warm spare configuration is the redundant hardware.
Switches in warm spare/HA will require two individual licenses.
I would like to know what will be the Impact of physically stacking the two MS425-16 switches when one of them is not licensed in an organization using per device Licensing model?
Will the stack configuration option be available?
If the stack configuration is available and I configure the stack, what will happen if I the grace period of  the not-licensed stack member ends.
Will the whole stack stop working after the one switch grace period?
KarstenI
Your quote is about the security appliances. A warm spare MX doesn't need an extra license. But for the switches, every switch needs its own license, regardless of any stacking.
For the rest of the question: You really should not plan for being unlicensed. Always make sure to have appropriate licensing!
For the time after the grace-period: The documentation mentions a "shut down" here and then. Actually the devices keep running, but I would consider it irresponsible to knowingly run into this state.
@KarstenI Thanks, what happens if we stack them and the grace period for the unlicensed switches expires?
This happens https://documentation.meraki.com/General_Administration/Licensing/Meraki_Co-Termination_Licensing_Ov...
Ryan / Meraki Solutions Engineer
