MX - Is there API call that provides data on negotiated link speed and duplex?
LearningIsFun
MX - Is there API call that provides data on negotiated link speed and duplex for the MX Appliances?
Not the settings that are configured, but what they are actually negotiated to?
Thanks!
Mloraditch
I'm not aware of any and just paged through everything that might and don't see it anywhere. It's not something you can change on the WAN or LAN on the dashboard so I expect it may be truly a local only configuration.
RaphaelL
Like mentionned , I really don't think you can get this info at all.
Since my MX are all connected to MS , I can check the MS uplink port status to see the negotiated link speed and duplex
LearningIsFun
Sadly unavailable seems to be the results.
Looking for it on the MX WAN ports, but LAN ports would be nice as well.
