Thank you for your response.
However, during my current testing, I observed the following behavior.
When I added the spare MX device to the dashboard network, I confirmed that the primary MX LED changed to a rainbow state.
At that time, packet loss was observed from the client side.
After confirming that the primary MX LED had changed to solid white, I powered on the spare MX device.
While the spare MX was coming online in the dashboard, no ping loss was observed from the client, and the primary MX LED remained solid white.
Based on your explanation, I understand that simply adding a spare MX to the dashboard network
should not cause any service impact.
However, in my test, the service impact occurred when the spare MX was added to the dashboard,
while no service impact occurred when the spare MX was powered on and came online.
For reference, the client is connected to the LAN port of the primary MX.
Could you please explain why this behavior occurs?
Best regards
