Hi there, i am new to Meraki, my current employer has several of our Meraki MX Firewalls web interface exposed to the internet.
Is there any guidance on how to either take the web interface down or hide the company data exposed on its pages?
Solved! Go to solution.
On the Firewall page you can set access to none.
Documentation covers the Local Status Page in great detail https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
Specifically your question is covered in this section https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/Using_the_Cisco_Me...
There's no way to remove certain data from the page but as said above, you can disable the local status page.
This is the answer I would use.
