Thanks bro for this. I've already read these articles as well.
Ok. So on our setup, the WAN uplinks are not in HA. Meaning, ISP1 is only for MX1 and ISP2 is only for MX2. Hence I cannot use the warm spare configuration that uses the uplinks.
Yes there will be VRRP on LAN side for the heartbeat. However in our setup, the LAN interfaces of the MX are configured with IP address (done by creating a VLAN x with y.y.y.y/24 address and associate that VLAN on a LAN port of the MX).
Let's say I have:
MX1
- VLAN10: 10.10.10.2/24
- Port 1 - access mode vlan 10
MX2
- VLAN10: 10.10.10.3/24
These MX's port 1 are connected on the switches. Behind the switches are L3 devices (e.g. router). I need to configure the routers to have a static route points to the VRRP IP of the MX so that when MX1 fails, the router at Site 1 will use MX2 and ISP2. if the MetroE goes down, both MX will go active.
Terry VASQUEZ Jr.
