Hi All
What happens if the LAN side fails in a HA scenario on the MXes? I couldn't find anything here or on the forum
https://documentation.meraki.com/MX/Networks_and_Routing/Routed_HA_Failover_Behavior
Will the one with the connected LAN become primary? suppose lan cables unplugged or damaged
Also when we click on the swap the primary and spare in a HA, what mainly happens here?
Solved! Go to solution.
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair#Dual_Ac...
Swap primary/spare is based on the vrrp prio and swaps the dashboard view old spare is then primary
https://documentation.meraki.com/MX/Networks_and_Routing/Routed_HA_Failover_Behavior#VRRP_Mechanics_...
Yeah
We tested it now.. both will become masters simply..
