MX Blocking services
AnthonyMaddick
Hi All,
This is a bit odd and we have been going in circles.
We are an Apple service center. When we run Apple service diags through the MX it blocks it. We have tried to open the firewall but have spent a lot of time and still cannot get to work.
We have a permanent server on-prem and then the client machines come and go (customers machines)
Can we allocate a port (lan4) on the MX68 to be fully open? and then we run the server and client through port 4 to avoid data being blocked?
Regards
Anthony
6 Replies 6
Ryan_Miles
Does the event log or Security Center show anything? Maybe IDS/IPS or AMP are catching something and blocking it? Or, even content filtering?
The server and clients are all behind/on the inside of the MX?
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
I cannot see anything being blocked, I will double check as there are a few events.
The server and client are behind the MX
If you can't apply a group policy to a VLAN.  In the group policy have it allow everything.
I am really having trouble figuring out what event could be causing the block in the events log. There are 80 events for the server so I assume one is the culprit
Si i have been reading the Apple resources.
This is the part that is going wrong.
  1. For OS-based diagnostics: The UUT searches for and NetBoots to the OS test agent image from any available local NetBoot server. The UUT will send a BOOTP/NBSearch broadcast over its LAN to reach any available NetBoot server. The first NetBoot server on the LAN to hear that request will respond. The NetBoot server will send the OS test agent image file via TFTP and NFS over NetBoot. The UUT will restart and NetBoot into the OS test agent to run the AST 2 OS diagnostic.
How would i see if something is being block during this process?
