MX-64 - WAN 2 Setup
ACETech
MX-64 - WAN 2 Setup
MX-64 user is changing to a new ISP.  In a previous question, it was mentioned that a solution is to setup a 2nd WAN port.
In reading and watching videos on this being done, I read 2 conflicting remarks.  The 2nd WAN port needs to be disabled, as in a 'warm' fail-over or it could be used to load balance.  Note the current ISP will be cancelled as the provider so fail-over is not a option.
I understand I can setup the new WAN statics on the 2nd WAN port and unplug the current provider from the WAN port.
Thanks.
Mloraditch
I'm unsure your exact question but here goes. The MX64 allows for 2 WANs, you change port 4 from a LAN to WAN on the main Appliance Status page. You can then activate WAN2 and make sure it works, Once working you can remove WAN 1.
Technically for the brief moments both WANs work it could failover but WAN 2 can be the  primary WAN with no WAN 1 setup.
If you are onsite you can access the local status page and locally just update WAN1 to the the new info and then change the cables.
There are probably a couple of other order of operations you could do. I do recommend if you only have 1 WAN to eventually have it located in WAN 1 on this model as the dual nature of the second WAN can sometimes be problematic if you ever need to reset things remotely. The Port can revert to lan functionality. It's rare but it happens.
2 Replies 2
Mloraditch
ACETech
Thanks.  For some reason, my own mis-reading probably, when setting up the second WAN port I thought i would see a button to make this either load-balancing or failover.
I am making this harder than it is.  With only a few numbers for the new ISP static WAN IPs, that's easy.
