MX 450
Chavati
MX 450
Hi, i have an mx450 as my hub concentrator in my hq offices, how many spokes does the device suports? Now i have like 150 branches with mx84 devices and the device utilization of the mx450 is sometimes at 45%. Thanks!!
spadefist
The MX400 is 1000, the MX450 actually supports 1500 tunnels, but as Adam suggests keep an eye on device utilisation as your mileage may vary.
Adam
According to this https://meraki.cisco.com/lib/pdf/meraki_whitepaper_mx_sizing_guide.pdf
That MX450 supports 1000 concurrent VPN tunnels.  So even if every one of your 150 branches had dual connections that would still only be 300 tunnels.  Although I'd keep an eye on the utilization.
spadefist
Chavati
thanks for your answer!
