MX 450 OSPF SLA
Hugo2
MX 450 OSPF SLA
 I need to solve some doubts, I am about to implement in my Network 4 Meraki MX 450 but I need to know if the MX can redistribute static routing and that routing tie it to an SLA, Since when one of my sites crashes or stops working they are announced by another MX through OSPF, the MX450 support this configuration? OSPF with SLA´s?
Thanks for your help
Accepted Solutions
KarstenI
Re: MX 450 OSPF SLA
4 REPLIES 4
KarstenI
Re: MX 450 OSPF SLA
Re: MX 450 OSPF SLA
@KarlH is right, it won't do static route redistribution.
You can do tracked routes.
https://documentation.meraki.com/MX/Networks_and_Routing/MX_Routing_Behavior#Static_Route_Tracking
Hugo2
Re: MX 450 OSPF SLA
Thanks for your help ! It is clearer to me
Hugo2
Re: MX 450 OSPF SLA
thanks for you answear, It is clearer to me
